She did look grand though...shame it had a fault light ruin the moment 🙄
It also dropped out of reverse into neutral later in the day, also I get it randomly telling me that it’s not been left in neutral when it was!
It is once again...back with the dealer on Monday for them to try and locate a bulkhead rattle, so this gearbox issue needs attention as well now...could it be a software /geearbox update is required?
Just got this same "gearbox fault" message tonight while driving and wouldn't upshift. Pulled over, turned it off, waited a minute and turned it back on -- message went away and shifting resumed normally. Googled around and found this post. What did you end up finding on your gearbox fault issue?
Software update for gearbox...whilst in for service (so far...so good)...although still get the odd ‘gearbox not left in park’ message even though it was left in park!
Yes, I get that occasionally also, even though engine is shut off, gear selection was Park, and gear selector depressed itself. Doesn’t give me confidence when truck is left parked on slope!
You cannot create new threads in this forum You cannot reply to threads in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
