  • pdes
    2019 Discovery Sd4 (240) HSE Santorini Black
    Auto roof blind, is it controllable?
    Just got my MY2020 and was surprised to hear the roof blind open as soon as the car starts. Presumably, it closes some time after the car has been locked. I haven't hung around to see what happens. Why has this feature been added and can it be switched off? I can't see any reference to this in the car menus or in the iGuide.
    D5 HSE SDi6, 2019, Santorini Black, privacy glass, HUD, loads of gizmos!! πŸ˜ƒπŸ˜ƒπŸ˜ƒ
    Series 1, 1953, 86"
  • DG
    2018 Discovery Sd4 (240) HSE Fuji White
    Yes, you can switch it off and use manually instead, Smile
    Quote:
    AUTOMATIC ROOF BLIND:
    The automatic operation of the roof blind can be adjusted via the climate settings screen on the touchscreen display.
    When the feature is selected and the doors are locked, the roof blind closes automatically. When the engine is running, the roof blind returns to the previous open position.
  • pdes
    Thanks for this. I suspect I was looking at an earlier iGuide. I redownloaded and found it.
    Cheers
    Series 1, 1953, 86"
  • Labbix
    After my last update, the roof doesn’t open anymore to the last position it was on before I turned the car off (and before the update 19B it did), now the blind opens totally.
    Is it just me or a one of the JLR 19B software glitches that everyone has?
    If possible tell me what your roof blind does with 19B, thanks!
  • mordred1973
    on a 2017 model....does the same as with 18D, nothing....(although randomly we do find the rear blind has closed 50% after we have left the car!)
    2023 D300 Metropolitan, Hakuba Silver, Low Range, Solar screen, Deployable towbar, FBH, sidesteps.
