- RegG
Battery Charging
My 2020 Landmark is displaying the message "Low Battery - Please Start Engine" as soon as I get into the car. I suspect this is due to lack of use during the pandemic. I have looked at the LR Manual and it says that the battery has to be removed from the vehicle to charge it and this should only be done by and authorised repairer!
I was hoping that there would be a simple way of trickle charging the battery whilst it is in situ. Or have I got to risk taking the car out for a good run and go against the lockdown restrictions?!
Any advice greatly received.
2020 Discovery Landmark 3.0 SDV6, Portofino Blue
yes, you can trickle charge it by connecting either to the jump start terminals under the bonnet or I use the tow electrics socket with a CTEK MSX 10 (don't exceed 10A on the tow socket otherwise you'll blow the fuse).
MY2026 D5 Metropolitan D350 - on order......
MY2022 D5 HSE D300 - current, MY2019 D5 HSE SD6 - sold
- John C
I would imagine this is because there is not a lot of airflow around the battery in a way that there would be if the battery was under the bonnet and they are concerned about build up of gases. Or it maybe that you'd have to leave the boot open to charge it (for the cable)... in which case maybe there's enough air moving around.
2024 Defender 130 Outbound Dynamic HSE, Carpathian Grey
2020 SDV6 D5 HSE, Carpathian Grey, 2005 TDV6 D3, Cairns Blue 290K miler.
- John C
Good spot!
Bet that’s a CTEK!
- RegG
Thanks for that..... I will give it a try when the snow is gone and we have a dry day (car outside on drive).
