  • Discolife
    2019 Discovery SDV6 HSE Corris Grey
    Rear door won’t close
    Afternoon all, quick search I couldn’t find the answer. My left rear door won’t latch and we’ve had to hold it closed to get it home. Is there a known fault or idea what I need to order to fix, unfortunately now out of warranty. Many thanks
  • Popsdosh
    As it can only be recently out of warranty <I would have a discussion with the dealer as I dont think this is a common issue as it would have triggered a recall. If you ask them some dealers can be helpful but you usually have to get by the firewall ! thats the service booking desk, and talk to somebody helpful.
  • Russell
    2017 Discovery Td6 First Edition Namib Orange
    This is a common issue there have been a lo with the same issue. New lock mechanism required.
  • Popsdosh
    think you may have your doors mixed up as passenger doors opening on they're own is a serious matter.
  • Russell
    No no mix up it is a known issue and a lot of people have had it happen
    I actually carry two straps just in case to ensure O can get it pulled shut if it happens to me
  • Whippetman
    Gosh!
    One fault that I never experienced!
    HSE LUX, Aintree Green GONE
  • Popsdosh
    Says a lot about the D5!!
  • Lucy2
    2018 Discovery Sd4 (240) HSE Santorini Black
    Door latch failures
    This is a fairly common and very dangerous failure. I had my grand daughter in her child seat off side rear door flew open when turning a tight left turn what a bluddy fright we got. I thought at first she had pulled the handle but when I checked the door it wouldn't stay closed, door latch was goosed. had tape in car to tape door shut until we got home. The car was 3.5 years old warranty was with WD, went to LR latch was replaced, sorted but somebody will get seriously hurt or killed one day.
    Now a year later I'm having to replace the near side rear door latch because it's causing a problem with the alarm not setting itself, scared it might fly open as well. Apparently the lock mechanism has a modulator built in to it that tells the car it's locked then the alarm sets itself. New lock mechanism costs £150 ish doing it myself because LR can't look at it until mid Feb. Cheaply made me thinks. Sad
    PS same lock on RRS, RR D5 prob Velar.
    Discovery Sport 2.0 ltr HSE Lux black 2016 gone. New to me 2018 Discovery5, 2.0 ltr HSE SD4 Black 22"
  • Scottlw
    2018 Discovery TDV6 HSE Lux Indus Silver
    Just had the same issue. Land Rover assist fixed on the first visit, but then did it again a few days later. Lock mechanism replaced today to fix.
  • Russell
    What year car was this please
  • Scottlw
    Its a 2018
