- NN21
Vehicle spec - new used owner
Hi, I’ve no doubt it’s on here somewhere but I’ve only just joined and can’t find anything using the search function. Where can I find my vehicle spec? I spoke with my local dealer (not where the car was bought) and they were no help. Thank you.
- Whippetman
No surprise there!
HSE LUX, Aintree Green GONE
- pld118
If you mean the ‘build sheet’, then that tells you everything the car came with from the factory… all you need to do is ring a helpful LR parts department, give them your registration or chassis number and they can email the build sheet to you. It won’t highlight spell out what were optional extras and what was standard, but you can then work out what the car has and has not got by reading it carefully and/ or doing research.
