- Chillyphil
Door catch, rear offside
Hi All,
Lots of flashing lights and car horns last night from other road users.
Rear offside door flapping open every time I turned a corner!
Looks like a problem with the lock mechanism.
The door appears to close but doesn't catch.
Any ideas of a fix, or, what should I be replacing?
Is it a replacement catch or a full lock?
Phil
- Mole HD
If the door isn't closed properly, you should get a dash warning light. If that's not coming on, the chances are there's an electrical fault in that door mech or the locking mech is closing but just not catching the striker plate. If it's that, you should be able to adjust the striker plate on the car side of the lock by loosening the bolts...probably Torx bits. That should bring it back in line so the lock catches... if the door latch is working but just not catching the lock plate.
I haven't looked at mine to see if you can...but on other cars the striker plate has a slight all round adjustment. If it's in line but the door catch itself isn't working, it'll need replacing or fixing. Check to see if that door lock clunks when you press the central locking button...the one on the drivers door that activates the child locks will do it.
If you can't fix it with a bit of WD40 or a bit of fettling and you need to replace the door lock mech...the OE replacement ones aren't cheap. Might find a used one cheaper from one of the online breakers on eBay.
Maltings 4x4 linky
eBay linky
