  • Road Runner 2017
    2018 Discovery Si6 HSE Lux Santorini Black
    Tow bar bolts.
    Well am pretty sure the bolts that are used are only suppossed to be partially threaded, for the tow bar. The LR ones were fully threaded. Replacement high tensile ones only partially threaded.
    Ended up adjusting the towball height to the middle notch as the lowest notch setting was making the trailer pitch forwards badly. Even trying to use the rear suspension to correct it still never made much of a difference.
    Still pitches but not as much. May end up changing it to the top notch. Also fitted a 50mm aluminium spacer block to it. Can see the tow bar far better now on the rear view camera.
