  • benlawers
    2017 Discovery Sd4 (240) S Namib Orange
    Fan on max
    Just back from the dealers for second time of middle row double seat coming off runners.
    It appears the latest fun is the interior fan is stuck on full power. Anyone had this?
  • rogersmj
    No, i've had an issue whereby the fan is set to hot, but blows out cold air? Also when you set the car to come out of the front facing intakes, it comes out from the top!
  • rsr
    I've got the blowing cold when set to hot issue too..
  • rogersmj
    Apparently another software upgrade needed to remedy this!
    My car is booked in for 4 upgrades at the end of Feb, including this and the famous V3 infotainment updates!
    This is why Google and Apple need to get deeper into the car business. Seems like the vast majority of problems these days are fixed via software updates. Air suspension fault? Software update. Using too much DEF? Software update. Transmission fault? Software update. Fan problem? Software update. Infotainment errors? Software update.
    Then your car could fix itself in your garage overnight.
  • decp
    Ireland
    Software Upgrade killed my AC module
    My LR5 went in for a 6 week checkup and a software update caused my AirCon to go to 100% on or 100% off. I cant turn the AC off and use fan only either. I dropped it back and they have to order a ner AirCon module Confused
