  • Dirty Trucker
    Towing a Caravan.
    At the moment my tyres are set for a light load,What PSI do you put in your tyreswhen towing a caravan?
    Ì usually set to heavy, and then its more or less left there all year round.
  • Dirty Trucker
    Cheers Craig, Have you tried it on the light settings?
    To be honest the tyre pressure is somewhere in between at the moment. Not high enough to except the high setting but well above the lo setting. There's only the 2 of us and the dog and we dont carry much in the boot so only the 120kg from the caravan. I couldn't say what the best pressure is sorry.
  • pdes
    I wouldn't tow with anything less than the max recommended pressures. I have tried various setups and from my own experience, towing a twin axle 650 Conqueror, stability is compromised if the pressures are set low.
    Series 1, 1953, 86"
