    Now I know what we're talking about, indeed it looks pretty good. Not sure if I would do this as my plates are black already, and a lot smaller.
    AndrewS wrote:
    Its the dynamic pack that gets the black bits not the black pack.
    https://disco5.co.uk/forum/thread542.html
    Thanks for spotting my mistake Andrew. I meant too say Dynamic pack 1, not Black Pack.
    (I was quoting from memory, plus they have changed the prices and names of the Packs).
    Incidentally Dynamic pack 2 comes with the rear number plate trim as well.
    DP1 is Exterior and interior.(more expensive)
    DP2 is exterior only. (cheaper) Thumbs Up
  • achichon
    Gibraltar
    DG wrote:
    aftermarket on Amazon
    https://www.amazon.co.uk/Car-Stying-licens...overy+5%22
    that looks like it sticks out of the boot shape/mould.. unless they take off the original number plate from under it...
  • DG
    I think they are just showing where it sits,.... I suspect you are right in that the number plate mount would be taken off and relocated onto the panel when fitting properly
    It doesn't look attached properly, on the left side there seems to be a gap.
  • beeker
    New Zealand
    Can anybody comment on the after market quality ?
    Looking ta this one
    https://www.powerfuluk.com/all-new-discove...black.html
  • milesg
    I have the one from Powerful UK. Mine fits well but needed a few extra numberplate sticky pads on the side where the plate sits to secure it properly. With the screws from the number plate as well it is very secure and looks good. Had it on a month now and the finish is standing up well. Before I put it on I treated it with Poorboys wax and ceramic coating. I also use Meguires Fast Ultimate Finish which helps keep the muck off it. This is filthy for the car but you can see the fit.
    PS - I know my rear plate is wonky, using an old plate that was pre drilled. Waiting for new one.
    HSE Lux in Silver / Black
