  • Mcoy
    Italy
    2017 Discovery Sd4 (240) SE Namib Orange
    Air conditioning air recirculation
    I don't know if it happened to you too, but when I insert the air recirculation (e.g. before to enter in a tunnel), it seem nothing happen and the car becomes a gas room.
    If I block the air recirculation by pressing the button until the light flashes, after 2' 30" it automatically unlock, exactly as it happens with the simple timed recirculation command.
    I called the dealer and he claim that it's normal: for me it's not normal, it must be blocked until my unlock command, otherwise there is no difference between "timed air recirculation" and "block air recirculation" commands.
    How does your "block air recirculation" command work? Is timed or fixed.
    Today (5 months - km.13.000) it appeared the message "tire pressure monitoring failure"... Censored
    Thanks a lot in advance
    www.disco5forums.co.uk/viewtopic.php?f=8&t=4327
    Yes seen one or two with the same problem.
  • Mcoy
    Italy
    Thank you,
    tomorrow I will go to the dealer...
  • Mcoy
    Italy
    After dealership intervenes, the recirculation now works correctly.
    Well you can't grumble at their response time. Shocked
