- HSEMY18
Easy entry/Exit feature
Just picked up my MY18 HSE on the weekend and loving it, can anybody let me know if the new discovery has the Easy entry/Exit feature?
If it does how do I get it to work?
Looking forward to exploring all the features on the car 🚘
- Down & Dirty
Taken from the i-guide
When easy entry or exit is enabled, the driver’s seat automatically lowers when the ignition is switched off and the door is opened. Upon returning to the vehicle, when the driver’s door is closed and the ignition is switched on, the seat returns to its previously set position.
The easy entry or exit feature can be enabled or disabled using the Vehicle Settings instrument panel menu. Select Convenience Features, then select On or Off from the Easy Entry/Exit menu.
- HSEMY18
Thanks Down and Dirty
I have Convenience features in the menu which I can tick ✅ but cannot see the easy entry / Exit feature in the menu. Can you see this feature in your vehicle?
- Chrismcnaz
Don't forget to put the steering column adjuster into auto by turning it.
- Down & Dirty
As above,must be in auto and of course set up memory seat
On my MY18 I don’t have the box to ✅ it’s dependent on the steering column being in the auto position,so if not in auto nothing happens
(This was confirmed to me by dealer)
- HSEMY18
Thanks for all the responses, been away on business so apologies for the delay.
I can confirm that the easy entry / Exit feature now works when the steering wheel is set to auto. However seat doesn’t move as much as I wanted, have resorted to using the 3rd memory seat function as my easy entry / Exit feature. 😀
- TazDaz
I have my steering column set to "Auto" but I don't get the Easy Entry/Exit Feature on my Convenience settings.
Maybe it's not on MY18 HSE's? It does kind of work but the seat barely moves
I've also set up seat 3 memory to be lowest and further back which works for us
