Just want to check with you guys, when pressing down (double click) on the rear windows control (on the rear doors) do yours stop part way down, and then require another press to get the window all the way down?
I was expecting the window to go fully down with the full press, not sure if this is a discovery thing or if there is something wrong or a setting that can be changed?
When you say 'all the way down' do you mean level with the door like the front two windows ?
If I press my button it only goes just a little more than half way down and will not go any further.
Here is a video which hopefully explains better, first 'full' press stops a couple of inches down, does exactly the same on both sides, so seems to be by intent just very odd.
Second press goes all the way down - well as far as it can !
Ah yes, I understand now. Mine is the same as yours.
When I read your first post I thought you meant your windows came 'right down' meaning as level with the top of the door like the front windows.
Mine is a Corris grey D5 L462 SE with the 3litre engine.
Not had it long but am getting used to it now.
