- Blackbeltbob
squeaky brakes
Well the car started squeaking under braking.
Very annoying. Blamed it on the heat however when on nights it still does it.
Asked one dealer to strip and clean them but they wanted an hour to diagnose the problem.
Called the local dealer and they said yip bring it in.
Turns out there is a technical bulletin for the D5 due to this issue.
They filmed it then stripped and cleaned it and sent the info to LR so hopefully get new parts next week.
Will keep you posted.
- mcunnin
Was it the front or rear? Mine did the same on the rear they changed out the pads. now its ok. it did not do it till you had driven about 4 miles then it would start every time I braked. they never noticed it on the first test drive probably because they only drove it 600yards. (handy the app records journeys) second time i drove and the tech came with me. all changed now.
2017 HSE Lux 3.0L Santorini Black
- Blackbeltbob
apologies for the delay.
I think it is the rears.
they are using way too much of the pads so I think its a balance issue mixed with an annoying mouse.
