    500 mile write up
    I have had the D5 for a few days now and did 400 miles in it yesterday so here are a few more thoughts.
    The car as a whole is very nice to drive, smooth, quick and a lot stiffer in the corners that the D4
    Ride quality on the 22” wheels is very very good, I guess 21, 20” or eve 19” would make it even better
    Driver’s seat is very comfortable but took a while to get it how I like as there is a lot of adjustment available
    Heated and cooled seats are lovely and it is nice you can choose base, back or both to be heated or cooled.
    HV as a whole is very very good with quick heating from cold start and temp seems more accurate compared to the D4, D4 I used to have set at 24 to be comfortable the D5 seems more like 21 t be comfortable
    Instrument panel is clear and the speedo and rev counter can be seen completely which is much better than my D4
    Steering is precise but when the lane dispatcher vibration is activated it feels stiff or seized, turn it off and the steering feels very different. The steering wheel takes a lot of getting used to it is thinner and squarer than the D4, at first was not keen but the more I drive it the more I like it
    Wipers and washers on the front are very good and the spray across the front screen is very good leaving a clean screen. However a line dries on the screen where the passenger wiper turns to go back down, roughly vertical from the interior mirror down the screen, never had this before on a car but it is the same or similar on Marks Ibiza
    The rear wiper and wash are very good. The washer operates two squirts with a short gap in between, the wiper is two speed, wipe one way then stop for a short time before returning or continuous, very nice touch and very effective.
    Rear end is not improved with regards to spray/dirt even with the spoiler, it collects as much dirt as the D4 did.
    Boot gesture opening is very good once you get used to how it works.
    LED lights are fantastic and very bright, HBA seems fairly good as well, front fog lights do not seem to give out much light will have to wait for fog to see how they actually are
    Stereo is fantastic, the Meridian sound is really nice and a massive improvement on the Meridian system in the D4, the DAB radio is also vastly improved with much better reception. The D4 did not work on DAB around where I live the D5 is faultless so far
    Reversing view from inside the car is not as good as the wide “C” post restricts this slightly but that is not a major issue using the door mirrors.
    The cameras and 360 degree view are all very good
    The interior mirror is odd, it seems smaller than the D4 and had no frame, not sure if I like it or not it may be just that it is different
    Storage in the boot area is not as good as the D4, the side panels that could be removed and things put in there are missing and this is a shame but not a deal breaker
    Sat Nav is very good, quick and accurate, speed camera alerts are spot on to the meter and the roads seem very up to date
    Washing the car seems a lot easier due to the curves
    One last thing, the testicle cooler vent under the steering column is not there on the D5
  • PeterW
    Hi Russell
    You mention speed camera alerts, can you elaborate please
    Peter
    HSE 3.0 V6 Diesel Corris Grey
    Seems an excellent review Russ. Thumbs Up The positives far outweighing the few minor negatives. I was concerned about the ride on the 22s as I have only driven the D5 on 21s which I thought was a good smooth ride. The D4 was on 19s which was an excellent ride also. I take it your using a foam lance for washing it? Any thoughts on waxes and polishes?? Plus with regards too the rear getting dirty, i think getting a pair of mudflaps should partially do the trick Rolling with laughter Thumbs Up
    PeterW wrote:
    Hi Russell
    In what sense, the nav has camera alerts on it and they ping up and count don well in advance including the new style on the M25
  • PeterW
    Thanks Russell
    These camera alerts are new? My D4 hasn't got them.
    Peter
  • DiscoStu
    It's a totally different Sat Nav system, and comes with alerts as standard.
    You can add similar to a D4,
