    A pillar trim seal
    Can someone do me a quick favour please..... Have a look at the rubber seal where the A pillar cover meets the windscreen. Do you have a 2-3 cm gap in the rubber seal near the top of the windscreen?
    My car was delivered with a stone crack in the windscreen. The windscreen was replaced yesterday and after I got home, I noticed a gap in the rubber seal. I assumed it had been damaged but then discovered an identical gap in the other side. Two matching gaps could be by design rather than damage so I just need to know if they should be there or not before I make a fool of myself by complaining.
    Thanks.
    Sorry, can’t help you at the moment as the car is at the dealer, if you don’t have an answer when it’s back I will take a picture for you!
    Mine is the original windscreen.
    Thanks.
    Good job I asked before shouting at anyone. Rolling with laughter
    True, it does look odd that said. Never noticed it before.
  • Gary
    windscreen
    Hi Will go and check now
  • Gary
    wind screen
    just took photo as seems same as yours
    Thumbs Up all normal then.
    I wonder why there's a gap? To let air in or to let it out?
  • Jambo
    Worth checking with dealer....
    I had a windscreen replacement and noticed the alignment didn't seem correct. Dealer checked it and found out that repair company had basically pulled the trim off without realising the correct way of doing it, so just glued trims back in place - hence mis-alignment!
    Now booked into body shop as repair needs to be carried out by them to rectify the fault. Costly mistake for windscreen co Rolling Eyes
