  • al cope
    auto lower after off road mode
    My old D4 used to lower back to normal hieght once you went above a certain speed after it had been in off road mode. My D5 doesnt - is there a setting somewhere for this?
    thanks
  • EMcC
    Mine does. It is quite a high speed , not sure what but I have come off road and forgotten I was still in high mode and when tootling along the road I get a 'Boing' and message 'Slow down or vehicle will lower' if I ignore it, it lowers of it's own accord.
    Yes it does lower.Off road in the D5 is +75mm. At 50kph (31mph ?) it drops to +40 but there's no bong and you are unlikely to notice unless looking at the vehicle dimension screen. At 80kph / 50mph it drops to normal ride height with a bong and notification if I recall correctly.
  • al cope
    OK, maybe I didnt clear 50MPH, but in the D4 it was somehng like 20mPH and you got the bong and warning and it lowered
    If the car is at access height initially, and you go over 20mph, we get a bong and a message on the digi dash, saying that the car will raise. The car raises to normal height automatically if going over 20mph.
    Mind you i thought that it lowers itself at higher speeds, i.e. 55mph i think approximately to aid stability and reduce drag. (I know the RR does this) but not sure if it applies to the D5 though, as i have never noticed a message or a bong at this speed Question
