  • Wineman
    Easy Entry and Exit
    Has anyone with a D5 found the easy entry and exit feature in the vehicle settings? I can't find it for the life of me and its certainly not working on my 1st Edition!!!! Manual says:
    EASY ENTRY AND EXIT
    When easy entry or exit is enabled, the driver’s seat automatically lowers when the ignition is switched off and the door is opened. Upon returning to the vehicle, when the driver’s door is closed and the ignition is switched on, the seat returns to its previously set position.
    The easy entry or exit feature can be enabled or disabled using the Vehicle Settings instrument panel menu. Select Convenience Features, then select On or Off from the Easy Entry/Exit menu. See INSTRUMENT PANEL MENU.
    2017 Disco5 First Edition (On Order)
    2013 Disco4 HSE Luxury / 2012 Disco4 HSE
    No it is on the switch for the steering coloum adjustment on the right hand side of the coloum switch it to auto Thumbs Up
  • Wineman
    Thanks Russell! Most kind! I'll have a look this am.
  • hatjoepeg1
    luckily mine was switched on by someone else !
    1986 90
    2017 D5
  • Wineman
    Found it Russel! Feel a bit silly as same as my D4, although online manual was deceiving.
    Would agree the manual is wrong.
    On subject on manual, any one figured out what the 3 symbols next to the gear position indicator on the dash are, one looks like a foot on a pedal, one looks like a brake warning lamp, cannot remember what the other looks like off hand, all three have a number on vertical lines underneath them and change colour from green, amber to red.
    I am guessing they are something to do with economy but cannot find it in the hand book
    They are activated or found by pushing the button on the end of the left hand stalk
  • J77
    It's how economical you are driving
    -Acceleration
    -Speed
    -Braking
