  • GEOBLRDISCO4_SOFAR
    13 pin on electric towbar
    Hi, just arrived to pick up my caravan in my 5
    Does it need an adaptor ,?
    My caravan is a 2018 bailey
    Be handy if somebody could check if your 5 socket looks the same
    looks like the socket cover needs removed abd turned 60deg
    The slot and pin plus 3 guides don’t seem to line up
    Can’t plug it onto the car
    Just checking if anybody else has had the problem
    Last edited by GEOBLRDISCO4_SOFAR on 14th Apr 2019 12:34 pm. Edited 2 times in total
    If the receiver and plug have the same number of pins I can’t see a problem. You put it in at and turn it 90 degrees clockwise to lock.
    Checked with Land Rover
    Nobody seems to have a clue
    I’m convinced the cover on the socket
    Is wrong
    The colar has twisted in the plug. The caravan should have come with an alignment tool to correct this, it can be done without but it is a pain in the arse. Have had it happen a couple of times now
    Try googling 13 pin colar alignment
  • Trevorb1
    This is how the caravan plug should look in unlocked state.
    Try partially inserting plug into socket so the square section starts to engage then gently turn outer collar on plug to return to correct algnment. That was how mine was just now when I went to take picture.
    Whew! thanks Gents, it crossed my mind to split the plug on my van cable but 1. It was freezing, i only had a tshirt on,
    2. I was convinced it would be the disco socket, new car, cable ok with my landmark just a few weeks back , hey, ho
    Many many thanks
    Van home, finally, thanks to you for the advice
    excited boys, time to get ready for easter break
    We are off in our new Elegance Grande on Thursday and looking forward to it
    So long as you don’t drag that Tintent round our single track roads, I’ll be happy.
    I wont drag it but I will tow it Rolling with laughter Rolling with laughter
    Expect a visitation when you least expect it! Laughing
