  • Notxal
    Auto open Sun Blinds on startup
    I liked this function as I've the black headlining.
    Problem is the car has just come back from a software upgrade and the blinds no longer automatically open and for the life of me I can't find any info in the manual or menu that enables this.
    Anybody any ideas?
  • DG
    Quote:
    PANORAMIC ROOF BLIND RESET
    The fixed panoramic roof blinds need to be reset if the battery is disconnected, becomes discharged, or the power supply is interrupted.
    To reset the panoramic roof blind:
    Switch on the engine.
    With the blinds closed, press the front of the front blind switch and hold it for 10 seconds. See ELECTRIC WINDOWS.
    After 10 seconds, the front and rear blinds fully close. If already in the closed position, an audible click sounds. Release the switch. Within 5 seconds, re-press and hold the front of the front blind switch until the blinds complete a full open and close cycle.
    Once the rear blind stops moving, release the switch.
    The blinds can now be operated as normal.
  • chaos_theory
    AUTOMATIC ROOF BLIND:
    The automatic operation of the roof blind can be adjusted via the climate settings screen on the touchscreen display.
    When the feature is selected and the doors are locked, the roof blind closes automatically. When the engine is running, the roof blind returns to the previous open position.
    Andrew
  • Notxal
    Thanks for the info, already tried the reset but this didn't solve it.
    Who would have thought of the climate screen! Thanks
  • DG
    I thought that was a given Laughing
    there's no option on my climate screen, is that because I have a 2017 HSE and its only on newer?
    Yes
  • sbrown
    When did this come in - I had a RRS loan car that did this recently but my MY18 Discovery HSE doesn't seem to - I have to admit I haven't even looked for an option as I didn't know it was possible
    Have a my18 lux that does it
  • TechnoTurkey
    My 17 Lux does not have this option
  • Rikster23
    I think if you have the blinds open when you lock the car, it will automatically close then. Then when you switch it back on, it should automatically open them again.
    If the blinds are closed at the time of locking, they won’t open when you start the car...
    Not sure if that helps.
    MY2019 HSE Luxury 3.0 SDV6 - Corris grey, Dynamic Pack, Black contrast roof, Adaptive Dynamics, Electric Tow Pack
  • al cope
    ^^^ thats how they are on my MY18 HSE
  • sbrown
    Thanks for the heads up on this - didn't even realise that settings menu existed! Sure enough option is there!!
  • milesg
    does this work if you have an opening front sunroof?
    HSE Lux in Silver / Black
  • chaos_theory
    Opening sunroof or not isn't a factor, just the right model and model year. Works with opening sunroof in my MY19 HSE.
    Andrew
