      - danrutter22
      Boot Liner
      Has anybody found a good boot liner. I’m not bothered about the main boot tbf, it’s more the drop down ledge that the dogs jump on to get it the boot. The carpet gets filthy when they jump in after a walk, I had one off discodunc from disco 4 site that was awesome
      - Whippetman
      I used some rubber pond liner that I had left over and secured it with some very sticky registration number plate pads off eBay and tucked the other end under the LR boot mat.
Perfect for the flap and easy to clean👍
HSE LUX, Aintree Green GONE
      - danrutter22
      - IndusD4
      The LR one covers the drop down bit of the boot, it has to elastic straps at each corner to attach the "flap" to the drop down shelf.
      - chaos_theory
      Yes I have:
Titan liner w/o rear aircon
Pros
- appears well made
- extensions for back of front seats and rear flap
- can accommodate 0, 1, 2 or all 3 rear seats folded
Cons
- requires velcro stuck on in the boot area (only)
- velcro doesn't stick well to carpet
Andrew
      - harrythespider
      Got mine from ukcustomcovers, (less than £50) Good fit, 2 pieces to protect drop down section, first one completely envelopes the plank 2nd piece attaches with velcro (really strong) to that cover and drops down a good 18 inches. Only niggle is the whole cover relies on velcro sticking to the cars interior. I am making different fasteners to hold everything in place to negate the velcro. I had to cut a hole in one side to accommodate the rear (boot) aircon. I have a dog crate in the back and to date no dog hairs on the cars carpets or fabrics because of the cover. Oh it wipes down easily and is waterproof.
3.0 HSE. climate HUD active diff. elec towbar. FBH and timed climate.Capability plus pack.split TV. surround sound. Intelligent seating. adaptive lights, wade sensing. 360 cameras.pro pack.cooler.advanced tow,  auto park,activity key+ more!!!!
