- Wineman
Oil levels
I was told one can see the level of adblue diesel cleaner by using the instrument panel menu, pressing the menu button on the steering wheel, and selecting it under the vehicle information section. The manual suggests I need to select "next service" from the menu, but I can't find that menu option. There is a select oil level menu option , but I get a message saying oil level unavailable when selected! Anyone else have any luck with either of these?
2017 Disco5 First Edition (On Order)
2013 Disco4 HSE Luxury / 2012 Disco4 HSE
- DiscoStu
Normally need engine not running to access service menu - it disappears if it is
- ken
What the inside Guru said
- Scrumps
Hi ,
On my RRS2 you can cheat the 10mins rule, simply pop the bonnet - you don't need to open it - then with power on you can select the service menu and check the oil level. you'll have to accept the "bonnet open" warnings with "OK" first.
Allow for the fact the oil is cold so the level will be slightly low.
Close the bonnet afterwards !!
Ad-blue mileage left is under the service menu - it will tell you how many miles / date to the next service and how many miles of Ad-blue you have left.
Scrumps
- Wineman
Cheers Discostu and to you Scrumps! Much appreciated.
