- pdes
Front lower light dislodged
I recently nudged a bollard which pushed the lower nearside wing in by an inch or so. Luckily, being plastic is sprung out with no visible body damage. However, the small LED light at the bottom of the wing didn't fully pop out and one side is now slightly further back than it should be.
Has any one dismantled the front wing and can advise if there is an easy way to access the light mount?
Series 1, 1953, 86"
