I have the Mid brown matt wood trim in my HSE Lux. With a full black interior including headliner I wanted to swap this out to the black trim. Does anyone know how hard it is to remove the wood trim and replace? I may even consider getting the wood ones wrapped so I can offer black or wood come sale time.
If its just the trim either side of the Touch screen / Ventilation controls then it is reasonably easy.
There is a pull off lower panel in either footwell and that exposes a set of Torx screws that hold the trim panel in place, once the screws are removed the Trim ''hooks'' out.
