    SD6 service and adblue interval
    For the guys who are lucky to have this engine:
    - Is the biturbo setup the real solution regarding the short intervals? Even when only driving short distances, will the service remain indicator stay ‘correct’?
    -And what with the adblue, does this interval stay more or less correct as well, more specific for the short runs?
  • Chopsy
    Hi. I have the SDV6 and have only had limited use of it so far. As regards the adblue - my range actually goes down slightly slower than the distance driven, which is positive.
    As regards miles to service, I can't say yet as I don't do many miles, so the drop in the indicator tends to go down by a monthly amount - not mileage based ie. 16000 ÷ 12 per month.
    Mine has done 6500 miles of mixed driving now and is still on schedule for the first service at 16100 miles.
    I've topped up with 10 litres of adblue so far.
    How do you check the distance to service mileage
    On steering wheel: menu button, than vehicle info, than next service.
    But the engine must be turned off during all this otherwise it won’t show up
    Thumbs Up Thumbs Up
  • Japseroony
    Did you get a warning light or just did a top up for the sake of it?
    I just occasionally check the distance to empty and if it says its ready for a decent top-up, I put in slightly less than it asks for.
    I've not run it down enough to get a warning yet.
    is it only the SD6 that tells you how much Adblue is wants? by TD6 just says "refill DEF within 1500 miles" (current warning) ..
    I am thus going to tip 10L in, but will want to top up again in a month before towing 2200 miles plus another 500 or 600 running about miles.
    MY18 TD6 says it as well:
    aha thanks, must only be 2017 models that don't tell you the quantity then. Never sure really, so tend to let it run to 1500-2000 miles and put 10L in. This time want to make sure I have plenty for towing the long distance plus a few hundred normal miles. I think towing it uses a litre about every 350miles and not towing about every 500miles. So long as it has over 5,000 miles on the range it should therefore be fine.
    just another thought! (I don't have too many) perhaps it is related to the Digital Dash? My 2017 HSE has analogue dials.
  • Trevorb1
    Remaining mileage for adblu came in at 18my, only reason it's related to digital instruments is that they became available at 18my also. My SE spec has the same analogue dials as your HSE but being 18my gives me the count down.
    mine has remaining mileages,just not how many litres to fill with, hence I tend to only put in 10L at a time once it gets down to 2,000 miles
    My MY 17 HSE has miles remaining for AdBlue, but also does not provide the liters to fill.
