      - Dangerdave
      Retro Fit reversing camera
      Okay, I’ve got a 2018 SE with no camera. I’d like to retro fit one with genuine LR parts. Anyone know if this can be done?
I’ve done a D4 camera retrofit. The main FAKRA was already in the headlining, just a case of buying a camera, loom and FAKRA from the gear selector to the back of the infortainment system then got it enamelled with Autologic. It was reasonably painless.
Not sure about the D5. I dont necessarily want to go pulling trims off unless I have to.
Alternatively anyone got ToPix and can access and give me the schematics for the Camera system from boot to infortainment please?
Update - spoke with Autologic, they are developing the software to change the CCF to allow the system to see a retro camera, but haven’t completed the programming yet. Looks like it will have to wait a while.
      - Wildboar
      Necro post ....but is it possible to retrofit a camera? I have the more basic SD nav screen
      - Dangerdave
      Physically yes, but you’d need the CCF enabled, that presents a problem at the moment.
      - Cradgebank
      ''Connects2'' make an interface module, albeit you have to use an aftermarket Camera, it does edit the CCF automatically and enables the Camera function on the OEM screen.
      - Dangerdave
