- Wildboar
Retrofit front fogs?
Hi was just wondering if it is possible to retrofit the front foglights?
There appears to be cut outs in the bumper.... What about wiring? Switches?
- Dangerdave
New wiring loom, steering wheel switch and I’d say a CCF alteration, which isn’t possible just now and that’s assuming that the wire is there from the bulkhead to the actual switch.
Id say it’s a non starter, but even if it were, it’s lot of work for basically a cosmetic gain. The headlights lights are fine.
- Cradgebank
They can be physically fit relatively easily, as you state, blanking plates are in the bumper, these are held in with 3 screws which are the same mountings as the Fog lamps themselves.
The problem as DD points out is the wiring, to wire them as per original would require a lot of work and expense however they could be made to work using a home made loom switched by either the rear fog light, a independent non OEM switch or use them as driving lamps and switch them through the headlamp main beam.
I can supply you a plug in headlamp break out wiring loom, if you wanted to use the main beam.( non commercial post)
