    Software bugs
    So, I am on 19B, latest version and have following bugs (without even looking for bugs, just noticing them):
    1/ sunscreen on ‘auto’: now it opens completely when you start the car as before it went to the last position it was in when you closed the car
    2/ rear screens: if you select a movie it does nothing on the main front screen, so you actually don’t know if it’s working in the back (version 18 had the same, only the first version did it correct: when you selected a movie it showed the screen with the time remaining of the chosen movie with a slider, so you knew it had started)
    3/ still no option to play the same movie simultaneously on both rear screens.
    4/ the field to choose if at startup the rear screens should be on or off is greyed out.
    If you find more of these annoying things, please add.
    theres hope for me as and when its installed then, as I "only" have an HSE so no rear sceens and being 2017 the roof screens don't auto open or close....so I may have avoided the bugs in this version lol
    The now known bugs at least Wink
