- Audioman
Fuse location for 13 pin socket
I had a wiring problem with my caravan which has resulted in no live feed on pin 9 of the 13 pin socket which supplies power for the active stability control on the caravan. Does anyone know where the fuses are for trailer connections on a D5? There are two fuse positions labelled ‘Trailer socket’ in the load space fuse box but neither of these have fuses in? Many thanks.
- MalithS
Have you looked in the fuse box at the rear right hand? Next to the battery. I think the fuses for trailer are in there
- Audioman
Sorted
Dealer replaced fuses 15&54 which are located in the load space fuse box. When I checked I thought these positions were empty but mustn’t have looked properly! Thanks to Lloyd’s Kelso who sorted foc 😁
