- Andeh13
Front PDCs auto on?
My Wife car, when approaching a front object her PDC come on automatically to warn her.
In my Disco, I have to manually turn them on as I approach an object, does anyone know if you can change this so they are permanently 'on' and looking for objects?
There is an option in their settings to make them turn on automatically below 6 mph.
Quote:
To manually enable the parking aid system, touch the parking aid icon (2). The icon illuminates while the parking aid system is enabled. Touch the icon (2) again to disable the system. The LED extinguishes.
The parking aid system also activates if Reverse (R) or Neutral (N) is selected.
The parking aid system can be set to activate automatically for when:
The vehicle’s speed falls below 10 km/h (6 mph).
Drive (D) is selected.
To enable the auto on feature, select the settings icon (1) to access the PARKING AID SETTINGS pop-up menu. Select Automatic Front Parking Aid ON.
- mordred1973
just infortunaley, on mine, they go to constant beep every time I go below 6mph, but the dealer reports no faul found, so mine are permanently turned off
- Andeh13
Very grateful guys, I will try this tomorrow morning!
