- frwamati
Headliner Removal Rear
Hi Guys,
I need to add additional wires (2x 0,75 mm2) from the rear window on the trunk door to the compartement where the battery sits.
Those 2 wires should be wired through the original plastic tubes (one on the left and one on the right side) - for this i need to remove the rear portion of the headliner to get them pass through.....
Does anyone know how i can loosen the headliner from its mounts that keeps them stuck on the roof?
I just need so much so that i can feed the wires through and then hide them behind the headliner and feed them down on the right side.....
Any ideas?
I guess its some sort of plastic clip that hold this in place?!
