    Rear light cluster crazing internally.
    Just washed the car at the weekend and noticed that the left hand side cluster on the boot lid has started too crack and craze internally all the way around. The outer left cluster on the body is fine though.
    It was initially all around the top, but its now it seems to have worked its way all the way around the light and is getting worse.
    At first i thought it was water that had gone into the cluster, after powerwashing it.
    Cars not moved in 4 weeks and been inside the garage, as am using mine daily for work.
    Anyone had this issue before ?
    Lights are smooth too the touch on the exterior, so definately not been hit, or impacted as i asked the Mrs and said definately not as she reverse parks at her work, plus anything would have been picked up on the rear dash cam she said.
    Doesnt look bad when cars wet, but when its dry its alot more noticable. A bit worrying if water gets into it now, and causes electrical issues down the line.
    A trip to the dealer after this lockdown is over and lifes back to normal, i think.
