- Ian2206
2018 (68 Plate) D5 Brochure
Hello everyone.
Im considering leaping from my D3 to a D5. Its a HSE Luxury on a 68 plate.
Does anyone here have a saved pdf of the 2018 MY D5 brocure that they can share with me. Or can anyone tell me what from the current standard offerings in the LR brochure on the LR www is unlikely to be fitted as standard to a 2018 vehicle.
Thanks in anticipation
- Equilibrium
Might be worth checking the build date as a 68 plate car could well be MY19.
My factory order last year was due to be built March/April and would have been MY19, but a slight delay meant it was built after the factory shutdown and was built in July 2019 as an MY20, registered in August on a 19 plate.
If ‘yours’ does turn out to be MY19 then I have the Pdf brochure for that. Also worth noting that between MY19 and MY20 pretty much nothing changed on HSE Lux models ((obviously I went through this with a fine toothed comb after being caught up in the switchover).
- Equilibrium
PS. Just to add, mine will be on a forecourt very soon, so if you’d be interested in a 2019/19 Carpathian/Glacier HSE Luxury with a fully known history then PM me and I will fill you in.
- IndusD4
I have 2 UK spec brochures, one saved in Aug 2017 which would be MY2018, the other saved in April 2019 so would be MY2019.
If you want these, I'll put them on my OneDrive - PM me for the link.
- Browser
- Ian2206
Thanks IndusD4. I would PM you but I don't yet have enough posts to do that.
- IndusD4
Sorted!
- Ian2206
