  • DarkyUK
    Left Boot Trim Removal
    Question Hi ALl,
    Has anyone removed the left boot trim before? I have the section for the workshop manual from Topix but i'm a little confused on removing the bag hook to get at the screw and also the deployable loadfloor cable.
    The images show whats in the manual, basically a simple picture and nothing more.
    Any help would be appreciated, it so I can run the cable harness for the deployable side steps.
    Cheers, Andy
  • DarkyUK
    I figured out the hooks, pull them up at about a 45 degree angle and they come out fine, still stuck on the cable though Sad
  • DarkyUK
    All sorted on this one, basically you need to use a small flat nose driver and push the clip either up or down then it can be removed.
