- Jemoss
Rear Passenger Window Stuck Down!
Hi all,
We've just been for a drive in our 2017 disco and decided to put the windows down. And now the rear right window wont go up!! It will raise about an inch then stop.
Any ideas?
Also does anyone know how to remove the door panels for a closer inspection?
Thanks for your help!
- Paramike
Hi this happened to mine,but it was the drivers window,according to the dealer motor relay had failed.there was no warning
- Jemoss
Thanks Paramike.
With yours did the window stop completely or did you have a small amount of movement too? Typical im about 4 weeks out of warranty too!
- Paramike
There was no movement at all just an audible click when the switch was pressed,When land rover assist came out he said it was a well known problem,which might put you in a good position for a goodwill payment from land rover
