  • scotty
    2017 Discovery TDV6 SE Indus Silver
    275/55 R20
    Is anyone runnings 275/55 r20 tyres,,, i quite fancy a set of BFG all terrains.
    just a bit concerned that they will rub, really don't want that happening.
    if you are running these, any pictures.
    thanks again
    scotty
  • harrythespider
    I'm on 275-55-20 Grabber AT3's and no issues at all, Could easily go wider.
  • scotty
    perfect cheers
  • Eniam17
    2019 Discovery Si6 HSE Corris Grey
    I’ve been on 275/55r20 duratracs since new, only about 4K miles but some good off-roading and haven’t had any rubbing or issues
  • Blackfly
    what's the road noise like?
  • Eniam17
    Not that bad, I’ve run duratracs and aggressive at’s for so long that I don’t notice it.
    If you’re someone who is used to stock tires or sensitive to road noise, you wouldn’t like them
  • Blackfly
    good to know, my roof rack makes enough wind noise so I may to notice the tyres Very Happy
  • RichardF
    I'm running BF Goodrich KO2 275 55r20 in this pic.
    MY2020 HSE Luxury 3.0 SDV6 - Eiger grey, Dynamic Pack, Tech pack, Adaptive Dynamics, Electrically deployable towbar, Center console coolbox
  • scotty
    that's exactly the wheel and tyre package i have went for,,, does look good Thumbs Up
    cheers
  • southpawstyles
    They look great. Any feedback on road noise for motorway/urban driving?
    Did you need to get your Speedo/Odometer adjusted?
    I’m close to pushing the button on a set.
    Thanks!
  • eelpout
    BTW, I just noticed the for 2021 the gloss black rims for 20"s are no longer an option. Have to go bigger to get them.
  • scotty
    https://photos.app.goo.gl/UcHQDRTLw4foMLzL8
    don't know if this will work
    Re: 275/55 R20
    thanks again
    scotty
    Currently on 275/55-20 Hankook snow tires, had 275/55-20 Cooper Discoverer AT3's - no rubbing on either, not at full lock or at any ride height. The Coopers were very loud between 35-55mph then quieted a little bit at highway speeds, got worse as they aged.
    In summer I now run the Defender spec 255/60-20 Wranglers (AT Adventure w/Kevlar, not DuraTracs), same OD as the 275/55-20, also no rubbing. These used to be called the SilentArmor, and they are both - dead silent at all speeds currently. Will see how they age.
