  • scotty
    2017 Discovery TDV6 SE Indus Silver
    not so good vibrations
    ok,,, so driving along,, get to 45-50mph and i can feel the cabin vibrating/shuddering, i can see the rear head rest vibrating in the mirror.
    no noise from anywhere, just vibration
    can't feel anything through steering wheel or brake pedal so assuming its not coming from wheels or tyres.
    checked tyre pressures- ok
    all weights seem to be intact on wheels
    and as usual, its just out of warranty by 2 months.
    anyone had similar issues
    thanks again
    scotty
  • Trevorb1
    Scotty, is it road or engine speed related? Try manually selecting another gear and see if the road speed at which it happens changes, I would suggest try at least 2 different gears, at that speed it will be in 6 or 7 th gear. If its same road speed all gears its drive line related, is it same during acceleration and overrun, also try dropping into neutral. If its road speed related my first suggestion is to get the balance checked on all 4 wheels and see whether that fixes it.
  • Trevorb1
    Scotty, see from another post that you may be running non standard wheels and tyres, has this issue occured since changing the tyres? The D7u platform is sensitive to tyre balance and tyre runout and that could well be your issue.
  • scotty
    thanks trevor,, i will try what you are suggesting and post back.
    i haven't actually changed the wheels and tyres yet,, hopefully they will be here next week so i can put them on to see if that makes any difference,,,, better or worse
    appreciated
    scott
  • harrythespider
    If you're not feeling it through the steering it's probably not the front. wheels.
    try substituting the spare for the rears
    If no change then unfortunately its probably a trip to the stealers
  • scotty
    problem solved,, gradually got worse today, so on closer inspection of tyers, the back one was shot, big tear and a massive lump in the middle.
    must have been coincidence that when i checked before the bad bit was down the way.
    hopefully new wheels and tyres will be here tomorrow
    ill try and get picture but can't figure it out
    thanks for all the help
    cheers
