- kaya
Tailgate problems inner ad outer
For about a week now, my inner tailgate does not open anymore when I push the button on the remote control. It doesn't even open when I pusch the switch in the trunk. I had been hearing motor noises from inside the hatch but not anymore.
The outer tailgate now opens only a bit (like 20-30cm) then stops. It only opens bit by bit everytime I push the remote button. Pushing the under dashboard switch it opens and shuts normally.
I have been reading here in the forum but don't seem to find the proper solution to either one of the problems.
Greetings from Bavaria,
Kaya
- Darras
Think you’ll find that one is beyond any words of wisdom anyone here could offer apart from book it into the dealership.
- grabar
i had a similar problem, it had to go into dealership, they said a cable had broken, it was fixed under warranty
- TechnoTurkey
I had the same issue, dealer repair under warranty. I think they fit an uprated part to prevent it happening again.
