  • Lucy2
    Air Suspension
    Hi folks
    This is just a post to help others that might have the same problem as I just had.
    We were away in our caravan ( Moffat ) for the May bank holiday & on our last day jumped into car & the suspension never moved up to normal height, stopped car played about with switch made sure all doors were properly closed but to no avail. Phoned LR assist they sent out technician first thing he done was to listen in the boot o/s & when pressing the rear buttons to lift or lower suspension there was a hissing sound this turned out to be the pressure switch it had split at the seam. Luckily the technician had a new one in the van because it's a common problem. So within an hour car was fixed & back on the road. Thumbs Up
    The valve is about the size of an aerosol lid which fits kind of half way inside the compressor.
