  • Eniam17
    2019 Discovery Si6 HSE Corris Grey
    D5 Running 33's
    I am in the US, is anyone over in the UK running a D5 on 33's? I'm looking at adding the compomotive 18's and would like to know what modifications (if any) are needed to run a full 33 on these?
    Thanks for any input
  • johnlad
    I’m running compomotive 18” wheels with 32” tyres and there’s still quite a bit of room around them. Mine is on the standard height settings. I think 33’s would fit but the tyre width is probably going to be the deciding factor.
    Also the comps only just clear the brake callipers, you might have to grind a little bit off the web on the calliper.
  • Eniam17
    That is what I thought as well as far as the space. I’m running a 275/55r20 and have a good amount of room. Another guy I know is on 285/55/20 and has done extensive off road travel and he has been fine.
    Supposedly the 2020 brake calipers are fine with the 18” compomotive wheels, but I’ll look into that more.
  • Alexoc
    Ireland
    Anyone running 275/60/20 (33”) without a lift kit?
