Great option 👍🏻 , kindly could you share photos of your discovery with the led bar ? and how its connected / attached to the OEM roof rails ? i hope i dont need to drill the roof to install it 😅
Here you can see how it is attached to the rood bar.
Sadly, mine has a slight manufacturing fault in the pain that has flaked, and the company that installed it as so crap that they don't want to take responsibility for it.
The cabling was very easy... It runs down the inside of the A-pillar. There is a relay under there.
Then I have a switch that is inside the cabin near where the switch for the boot door is.
The cable comes through one of the rubber grommets in to the cabin.
I I lay know because I also wanted to do exactly that with my D5
In the end I did the best that I could... I have a discreet winch, and the led bar.
I already had all the off-road options, and I like the black 5011 wheels that I already have.
All in all, I am very happy with my D5 and plan to keep it as long as possible!! It is by far the most comfortable LR vehicle that I have driven, and I have had D2s, D3 & RRS (L319 and L320), FFRR L322.
