- sportcoupe
You changed your wheels and tires yet again?
Ordered - HSE 3.0 V6 Diesel Kaikoura Stone 20" Black pack + more.
2016 Jeep Wrangler Unlimited Rubicon
- AndrewS
Yes, the reason is the TPMS sensors apparently work different in a D5 compared to a D4. In a D4 you simply swap wheels at leisure and the car automatically detects the sensors. However in a D5 the individual sensors are coded to the car. So at the moment my 'off road' set of wheels are in my workshop awaiting the outer beads to be 'popped' so I can record the numeric code of each sensor. I can then re fit the wheels/tyres inform the dealer of said codes who will code them to the car.
- sportcoupe
That is very good information for all of us that may change tires and wheels.
- Gareth
It might become a pita for those that want to regularly swap wheels. Maybe the chaps at GAP are taking note, and will release a new 'tool' ?
- Russell
Andrew do you know how many codes the car can store, can it store 10 sets eg off road and on road tyres?
- AndrewS
I think the car can store more than 5, watch this space,
Still not convinced its a dealer fix.
- Russell
I am awaiting a friendly service manager to rely as well
- ken
Andrew shame your not here
Its normally as simple as Reading the Code with a TPMS reader then recode the virgin valve
AM EZ sensors come as a "Virgin" value so a little poke and off you go
I'll check compatibility for the D5
- Russell
Got feedback from dealer after car went in for a couple of minor things. They have said that they can only programme 5 sensors and the car will not take any more, it just over writes the others after that
- ken
So they are self calibrating then ?
- Russell
Not sure what you mean.
With D5 you have to log the TP valves with the car and the car will only accept 5
- Russell
Will have a word with my lad and see if they can do that where he works
- Russell
Ken
Quick question, if the TPMS valves in the spare wheels (winter wheels) have already been programmed with a code can they be re-programmed with another code, eg the code of the wheels fitted to the D5? Or are they a single shot once coded cannot have another code added
- AndrewS
Finally got the off road wheels and tyres back on the car today with Disco5 sensors fitted. I've only driven a few miles.
Went into vehicle information and found that the 4x4 tyre pressures were being displayed. So it looks like re-programming may not be required. A longer run will be required to confirm this.
