  • LR Max
    2019 Discovery Td6 HSE Lux Loire Blue
    Lower Dash Removal
    Good morning,
    2019 D5 HSE Lux TD6
    I'm hoping to remove the entire panel under my steering wheel and also hoping that the little "dash" pocket that is on the panel. Of course its so tight underneath the dash you can't get to anything nor see.
    I was able to remove the triangle side trim off the end of the dash board and remove the one torx. But what is holding this panel on up by the steering wheel? Anymore disassembly required?
    Thank you.
