  • simonb85
    Inner rear light replacement
    New here. Have a 2017 HSE disco 5. I have recently replaced the inner rear light after cracking it. Don’t ask.
    However, the indicator does not work at all. Had another replacement part sent out just in case it was broken, this wasn’t the case.
    Does anyone know if it needs reprogramming? My old light with the cracked lens still works if I plug it in, but 2 new lights both had the indicator not working. Genuine Land Rover parts as well.
    Any help would be greatly appreciated.
  • Trevorb1
    Have you got the correct inboard light unit? S &SE trim levels didn't have the indicator on the inner light units I believe
  • simonb85
    Hi, thanks for the reply.
    I believe they’re we’re both the same parts. On inspection all part numbers and numbers dotted around the lights on the plastic are identical on all 3 lights.
  • harrythespider
    What does the other side do?
  • simonb85
    Other side works fine. Outer most part of the light on the wing still works as well.
