  • Joakim Svensson
    Sweden
    Front Runner roofrack
    Hi all!
    New on this forum and just bought a 2017 D5 HSE but have had Land Rovers since 1999.
    My first question is if anybody knows if i can mount a frontrunner roofrack without the roofrails?
    Mine doesen’t have the roofrailsand i cant find any info about it
    [/quote]
    Yes, but you may need to pull the sliding roof fuse as there may not be enough clearance to open it, and you wouldn't want to run the risk of damaging the panel.
    Actually no, I take that back. Here's the FrontRunner website, where you can download install instructions:
    https://www.frontrunneroutfitters.com/en/u...k-kit.html
  • Joakim Svensson
    Sweden
    Thanks for your answer!
    But where the roofrack mount to the roofbars, it’s the same bolts that holds the roofrails so it should work or do i have bad luck when thinking? I dont have sunroof either so that wont be any problems Smile
