- Molesworth
Middle row not folding flat
Before I raise this to the dealer, can I check there’s no trick to doing this and that they should both fold flat using the switches in the boot?
- Craigp
Only done it once since picking up my new car but it did look a little disappointing to how flat it was. Certainly didn't seem to lay as low as my 2017 model but that was manual as opposed to electric. I will try and take a picture later on.
- Wildrnes
how old is your car? mine folds flat (2017)
- Molesworth
Brand new. And the left side doesn’t fold as far as the right side either
- Wildrnes
i would be talking to dealer
also when you are in the stealership make sure you test the seats in the showroom...
- Molesworth
- Wolfpack
Assuming the seat belts are undone, nothing on the seats and the headrests aren’t fouling the front seats?………
This happened on mine when I first got it. From memory it was down to the position sensor setting. For the life of me I cannot remember how I fixed it …..but I did.
I am now having the reverse problem. The single seat goes back upright fully and then moves forward of the other pair by an inch or so. I am guessing that it too is a repositioned sensor setting ….but as I can’t remember how I fixed it going right down I cannot fix it not going fully back (apart from brief pulses on the switch to nudge it back.)
- Trevorb1
Middle row of seats is slightly raised on face-lift to improve comfort, might be why they don't fold completely flat like pre face-lift. Seem to recall someone else raised this issue as well.
- 747_JK
Slightly raised on the facelift? Interesting... Wonder if this gives a fraction more leg room?!
- Craigp
- al cope
Have you tried holding the switch down, as this will force the seats down a touch more.
- Wolfpack
- Craigp
Hi Wolfpack I wasn't the originator of the query just trying to be helpful. I've sort of excepted that that's as good as it gets. Waiting for Molesworth to come back
- Wolfpack
Oops
- dc130.john
Had this on my 21MY. When I looked, the near side middle row headrest was not folding enough and causing the seat to stop folding. I pushed it in and all ok.👍
