  • Looneyfitter
    Radar blocked cruise not available.
    Hit a bird some time ago and since the CC hasnt worked. The lower valance is damaged and i believe the radar is behind this?
    Is it possible to remove the valance to access without removing the bumper?
    Cheers.
  • nebc100
    You are correct… the ACC sensor is behind there… sadly only way to get at it is to remove the whole bumper
  • Duckers
    Have the same problem, fault code C1A67-78 (AF) "forward looking sensor, mechanical failure, alignment or adjustment is incorrect"..
    Quote from my local JLR dealer of £225 plus vat to correct. A relatively straight forward job job to do DIY but I don't fancy risking the front end while working single handed.
    Regards
  • dublindisco
    Ireland
    2019 Discovery SDV6 HSE Santorini Black
    Hi I have the same error code. Can you advise how you fixed it or what LR intended on doing to fix it.. I was quoted €2,000 by LR stating they need to change the front facing camera..
  • Duckers
    In my case it was the radar unit bracket that was bent,(slight pressure on the front bumper can distort the bracket)
    I discussed the problem with the LR Main Agents and asked them to change the bracket and realign the unit cost £250 ish.
    Hope this helps
    Regards
  • dublindisco
    Ireland
    Great thanks Duckers. I just replaced that bracket yesterday, it was slightly bent but nothing major. I’m still getting the same error msg but I assuming it now has to be re calibrated ?
  • Duckers
    Splendid, yes as far as I know re calibration is required, just how that is undertaken I am unsure probaly a job for diagnostics and a short drive to reinitialize the system.
    Hopefully someone on the forum will haves more info.
    Regards
  • dublindisco
    Ireland
    Great cheers
