  • Morepower
    2017 Discovery TDV6 HSE Lux Carpathian Grey
    Error codes
    Anybody know what these codes mean, they won’t clear, could this be the reason my front camera doesn’t work?
    Looks like a top level summary of the faults present. Not familiar with the software you are using but can you select each ecu and see what the fault codes are? The actual fault code should then give you more insight into what is wrong. The image processing one might shed some light on the camera, probably a fault with that individual camera if all the others are working.
  • Morepower
    I’m using the IID tool, this is the breakdown of each one
    B12BE-19:
    Quote:
    Refer to the electrical circuit diagrams and check the front proximity camera power and ground circuits for short circuit to ground, short circuit to power. Repair the wiring harness or install a new front proximity camera as necessary
  • Morepower
    Got it booked into the dealer to sort, thanks for your thoughts guys👍🏻
