  • Marsie
    Heated windscreen fault
    Due to the frosty starts this last week we have been using the heated front screen. Unfortunately only half of ours is working and it's not the drivers side😕 . I have located 2 40a fuses in the under bonnet fusebox but both look OK
    Are the connectors under the a pillar trim? And is there power and earth connections?
    Paul
    2017 3.0 First edition. Silicone silver with black pack
  • gtp4all
    i have the same issue except it's the passenger side that doesn't work. i took it into the dealership and they advised that i need a new windshield at a cost of >£1,000.
    I did wonder about the fuse but could not identify from the user manual where it was located, I will have a look under the bonnet as you have done.
    if we do need new windshields it may be more cost effective to use a specialist windscreen company rather than Landrover...
    It’s a shame you haven’t got a crack on the windscreen. Whistle
