- Brjdisco5
Swapping engine
Hello everyone
Is it possible to replace the « ingenium 2.0 diesel twin turbos » with another engine more reliable?? Mine has failed at 100 thousand kilometers. Dealing with such engine is too expensive and the results are not granted. If not , then what’s the solution? Thank you.
- nebc100
Everything is possible… just depends how much you want to pay!!
- Brjdisco5
that looks good thanks
what engines suits it ? ( least modification and reasonable price) , thank you .
- nebc100
Sorry… you seem to have missed my sarcasm.
You can probably change the engine with a different one, but the costs will be FAR more than buying a while more vehicle.
There will be ecus that would have to be changed, the engine itself, probably wiring harness, exhaust etc…
I would forget the idea if I were you.
- Brjdisco5
oh yeah i’ve missed it for sure haha, i was hoping to have this solution, but now i’ll just forget it. i think i will change the block and timing chain hoping i can use it for more than 2 years. i appreciate your help sir thank you very much
